ENC Noise Reduction
- Solidcom SE features an ENC dual - mic noise reduction design. It can dynamically recognize environmental noise with a noise reduction depth of up to 20dB.
Clear Call Quality
- It offers clear calls, with a frequency response range of 150Hz - 7KHz and a signal - to - noise ratio > 71dB.
Waterproof and Design
- With an IPX4 - level waterproof design, the overall headphone adopts precise industrial design.
Automatic Frequency Tuning
- Equipped with an automatic frequency - tuning algorithm, it can automatically adjust the frequency when encountering interference and has a 350m transmission distance without visual - range obstruction.
Easy to Use
- It is ready to use right after being powered on. It supports up to 5 - way collaborative communication.
Mute Function
- There are two mute options: the MUTE button and muting by flipping up the microphone boom. The MUTE button supports the PTT mode.
Battery Life
- The fully - charged headphone has a battery life of up to 12 hours and supports charging while using.
Solidcom SE-2S
£220.00 £307.00
Solidcom SE-4S
£434.00 £603.00
Solidcom SE-5S
£550.00 £763.00
Free standard shipping on orders with a minimum paid amount of £70 (after discounts and promotions). Applies to all official products and services. Learn More >
Solidcom SE-2S
£220.00 £307.00
NOTIFY ME WHEN AVAILABLE
£220.00
£307.00
You Might Also Like
Astra P1 Pan-Tilt-Zoom Camera
Feature UHD 4K60 Face Detection AE 30x Optical Zoom AI Auto Tracking NDI®|HX3 Support ...
48 kHz/24-bit High Fidelity 3-Level Intelligent Noise Cancellation EQ & Reverb Adjustment Au...
Feature 48kHz/24 Bit AI Noise Cancellation Quick Charging Clip-and-Go AI Voice Tuning AI Auto-L...
